Results 1 to 10 of 10
Thread: Adjusting bolt
    Aug 2011
    Virginia Beach Va
    Adjusting bolt
    Does anybody have the correct size bolt for a 1966 MY ,the front ride height adjusting screw/bolt ?
    I seem to have misplaced mine .
    Thank you in advance.
    Doug Lehman
    Member #2825
    1966 912
    1978 911SC Targa fun in the sun
    Aug 2011
    Virginia Beach Va
    Does anyone have the correct length, color and size?
    Any help is greatly appreciated.
    Doug Lehman
    Member #2825
    1966 912
    Should be just a hex head 10 X 1.50, length the same as the other side, about an inch and a half, usually black oxide. Ace hdw. has a good metric selection.
    May 2006
    CT
    I think there were three versions of the torsion lever adjusting bolts. The attached photo shows all three.
    One the RHS of the photo are the adjusting levers and bolts used from 1965-1967. The levers are different and the hex head bolts are shorter than the 1968 version shown on the LHS of the photo. The two hex bolts are shown side by side in the center of the photo. The 1968 version of the bolt is longer.
    The top of the photo shows the version of the bolt used from 1969-1989.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Mar 2006
    Louisville KY
    This is off of a '67 It is just a regular bolt but it is rounded at the end. The plating is incorrect.
    Tony Proasi
    52 split window coupe
    Aug 2009
    SF Bay Area
    It's a frigging bolt
    All the adjusting bolts had rounded ends.
    Quick search found ... for what it's worth ......
    '66 - '68 999-083-002-01 12 x 1,5 x 40 8.8 strength Bostik finish (a modified version of DIN 961 fine thread bolt)
    '69 999-083-002-01 12 x 1,5 x 55 same same
    '70 - '73 914-341-117-00 I don't have a spec.
    '74 on 911-341-115 00 I don't have a spec.
    Aug 2009
    SF Bay Area
    Quote Originally Posted by 356hunter View Post
    The "66 - 68" bolt (40mm long) ended in 67, not 68 The one on the far left
    68 and 69 used the same 55mm bolt 2nd frm the left
    70 - 73 used the "914 bolt which has a small head on it (11mmATF) 2nd from the right
    74 on used a similar bolt to the "914" one but uses an 8mm allen, instead. On the far right
    Ciao
    Jim
    Aug 2011
    Virginia Beach Va
    Thank you all for the great info !!!
    JIm I bought a pair from you yesterday. I am not even sure what I paid but I am all in on these . I will of course find mine as soon as your arrive. But at least I know yours will be the real deal
    Doug Lehman
    Member #2825
    1966 912
