Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 57
Thread: HELP NEEDED!!! webasto gas heater serial #'s wanted
    Pay to play Schiefer's Avatar
    Jun 2008
    Norway
    Hi again,
    Because it is you, I skipped the last part of the Champion League`s match to snap some pics ;-)
    Will post the kardex in my project thread when we come to that chapter, but emailing it to you now so you can have a look.
    Looking forward to your conclusions, but this is what I see:
    - Raised area does not look like hammered by hand, (but no schutz???)
    - The lid does look like it has been taken off to be freshened up. Difficult to see, but at least some of the screws (replacement or not) have trace of black paint.
    If the pictures are not good enough, I will take more tomorrow in better light.
    gruß
    Name:  Smugglers box_1.JPG
    Name:  Smugglers box_2.JPG
    Name:  Smugglers box_3.JPG
    Name:  Smugglers box_4.JPG
    S-Reg #1382
    67S Lavender
    Senior Member moito's Avatar
    AUSTRIA (tu felix)
    hi Radmund.
    appreciate this ....must have been a boring soccer game...
    the lid is serial production and has been off the car(note also incorrect screws) ..it does not reveal much to me since it has been repainted but.the only hint that it could have come with the car is the traces of schutz on the inside ...
    does your car have those two prestole cages/or the two squarish holes where they fit in.
    the hole where the wiring harness enters the smugglers box could also give some information...does it look enlarged.
    thanks for the kardex. i wonder about the Abnahme-Besch. date...
    thank`s for your contribution
    what you have in 301744 is, what i call "the nylon cap type"
    unit #2015 and 2292 added to the data base
    pictures of the #2292 unit would be of great interest cause this is a serial# that would help to narrows down the gap for the transition from nylon to steel cap .
    the one in 304574 is most likely a red steel cap type..if you find time to take a pic of it would also be sweet.
    thanks much
    franz
    Franz
    Photos of heater 002292 in 303066
    John Schiavone
    Connecticut
    AUSTRIA (tu felix)
    Quote Originally Posted by John912 View Post
    Franz
    its a red steel cap type
    thanks a lot John
    Franz:
    So you will be the one who compiles all of this information into a comprehensive reference manual to expand upon the good work started by Brett Johnson and others? Would be nice!
    John Schiavone
    Connecticut
    May 2011
    Chelsea, Québec
    Hi Franz
    This is the heater from 304598...
    Name:  gas heater.jpg
    Name:  gas heater (1).jpg
    Member #1616
    AUSTRIA (tu felix)
    Quote Originally Posted by StephenAcworth View Post
    Hi Franz
    thanks Stephen
    i assume you don`t have the serial# handy? should be around #4500
    interesting to see that this car has the fine weave asbestos insulation pad and the two lip smuggler door seal ...
    May 2011
    Chelsea, Québec
    I'll get you the serial number... I'm at work and the Kardex is at home. If its not on the Kardex, I'll get the number off the heater but that'll be a couple of weeks as the car is in the shop at the moment...
    S
    Member #1616
    Hope this helps. #303366, 12/65, Webasto #3364
    May 2011
    Chelsea, Québec
    #304598, 26.05.1966, Webasto 004595
    Member #1616
