Thread: WTB: CV shaft flanges
    Dec 2011
    Palm Coast, FL.
    I need a pair of the Early 4 bolt 2 pin shaft flanges with the fine splines. Let me know what you have please.
    ESR # 2300
    229 MPH 3.0 MFI 911
    Feb 2011
    Arizona
    Those are hard to find. Depending on the diff you are using you can change the internals and use course spline stubs which are quite common.
    LSR911
    I can't remember any 4 bolt, 2 dowel, fine spline drive flanges. Fine spline was either 100mm flange with 6/8mm bolts or 110mm flange 6/10mm bolts. 911 or 914 drive flange with 4 bolt 2 dowel were coarse spline.
    Quote Originally Posted by Bob Alfonso View Post
    Let me guess. You bought a LSD?
    I agree. Those appear to be modified 80-84 flanges- 76-84 if Turbo- with two threaded bolt bores drilled out.
    It would help to provide the flange diameter and bolt bore sizes for better identification, or the part number on the flange.
    Jon B.
    Vista, CA
    Dec 2011
    Palm Coast, FL.
    You got it Jim! We decided to go the route of changing both drive axels to something different.
    ESR # 2300
    Explain your application, year model and parts purchased, we all probably have a solution for you.
    Dec 2011
    Palm Coast, FL.
    3.2 with a 915 LSD going into a 70 RSR project. We decided to use new pair of SC Drive axels, no longer need drive flanges as photo above. Thank you all.
    Bob
    ESR # 2300
