i am currently restoring two 1969 911T.
would like to remove the tags to complete resto and install them again properly.
what do i use to install them again and where do i find them?
www.tcspeed.com
This may help a little...
http://forums.pelicanparts.com/porsc...vin-plate.html
Good question, tcs, most helpful. I've just got to the same point on my '68 stripdown, and was concerned about removal of the door paint tag. Some helpful hints on the pelican link as to how to remove those little rivets without damage to the surroundings, and some confidence that there's authentic replacements out there. Thanks.
It seems there's a few methods suggested for installing new paint tag rivets back in, ranging from superglue (!) to use of trim fixings ('square nuts') on the back. Will the Stoddard rivets press back into the original holes ok, or are there good tools/techniques required does anyone know?
Regards,
Mike.
Mikey C. ESR Membership #3333
http://www.mceporsche.com
stoddard has the paint tag rivets.
Any idea where to get correct VIN tag rivets?
www.tcspeed.com
what rivet is used for vin?
www.tcspeed.com
I'm in need of this info also... What is he correct rivet for the latch panel VIN tag?
Jones...
early S # 2626
'71 911T
'05 BMW 330ci
'22 Wills Sainte Claire
'96 S10 truck
Rivets are at Stoddard: https://www.stoddard.com/99919010130.html.html
Mike Fitton # 2071
2018 911S Carrera White
www.tcspeed.com
so are these the correct rivets?
www.tcspeed.com
