Results 1 to 10 of 10
Thread: door post tag and latch panel tag attachment?
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    i am currently restoring two 1969 911T.
    would like to remove the tags to complete resto and install them again properly.
    what do i use to install them again and where do i find them?
    www.tcspeed.com
    Oct 2008
    Burford, ON, Canada
    Peter Kane
    '72 911S Targa
    Senior Member MikeyC's Avatar
    Nov 2015
    Oxfordshire, UK
    Good question, tcs, most helpful. I've just got to the same point on my '68 stripdown, and was concerned about removal of the door paint tag. Some helpful hints on the pelican link as to how to remove those little rivets without damage to the surroundings, and some confidence that there's authentic replacements out there. Thanks.
    It seems there's a few methods suggested for installing new paint tag rivets back in, ranging from superglue (!) to use of trim fixings ('square nuts') on the back. Will the Stoddard rivets press back into the original holes ok, or are there good tools/techniques required does anyone know?
    Regards,
    Mike.
    Mikey C. ESR Membership #3333
    http://www.mceporsche.com
    Nov 2015
    stoddard has the paint tag rivets.
    Any idea where to get correct VIN tag rivets?
    www.tcspeed.com
    Nov 2015
    what rivet is used for vin?
    www.tcspeed.com
    May 2013
    Victoria BC Canada
    I'm in need of this info also... What is he correct rivet for the latch panel VIN tag?
    Cheers,
    Jones...
    early S # 2626
    '71 911T
    '05 BMW 330ci
    '22 Wills Sainte Claire
    '96 S10 truck
    Jul 2011
    Chicago Area
    Mike Fitton # 2071
    2018 911S Carrera White
    Nov 2015
    Quote Originally Posted by mfitton View Post
    the website says they are for bumper end caps. Would they also be the same for the VIN tag on a pilar?
    www.tcspeed.com
    Nov 2015
    so are these the correct rivets?
    www.tcspeed.com
