Results 1 to 10 of 14
Thread: 2 questions for front trunk specialists
    Dec 2015
    Bordeaux, France
    Hi, I'm starting to apply the paint in the front trunk, and have two questions for the specialists!
    -Are the snap fixtures (those that hold up the carpet) installed before painting? i.e. are they also painted over?
    -After the base paint, should I apply a light coat of clear coat? All the trunks I see are dull, like there's no clear coat...
    Car is a 72 targa, in metallic silver gray (925)
    Thank for any help, I've been digging through photos all weekend, but these details are hard to spot!
    Dario
    ____o0o____
    1972 Targa 911S (one day), silver gray (maybe), member 3337
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Florio View Post
    Dario
    q1 nope no paint over snaps
    q2 light coat of clear ...light overspray not a full layer but may vary dependig on the painter and if he had a binge weekend or not.
    i played a bit around with matting agent to not get the full gloss level
    Jul 2006
    Switzerland
    Mine was never restored in trunk and it has no clear coat.
    Is it metallic paint only?
    Usually its just a matt light overspray in body color.
    Snaps mounted afterwards, no paint.
    You might do a search on this board, as wheel wells, engine area, shock towers etc had their details.
    Registry member No.773
    Well done on the period correct drips at the shock towers...
    Peter Kane
    '72 911S Targa
    Senior Member Fubawu's Avatar
    May 2013
    I was thinking the same thing. Karim in regards to no clear coat, is it possible over time the light clear would have faded??
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    May 2013
    AUSTRIA (tu felix)
    thanks
    and an other example
    Dec 2015
    Bordeaux, France
    Wow, I was just going to say how great that trunk looked! Thanks for the picture and congratulations! now I have to ask about the door
    I'm going the route of painting the door jambs and then installing the front fenders as that appears to be what the factory did. It also makes good sense in my case because my garage space is limited and this will allow me to start installing things (like brake lines, cables, etc) before taking the jump to the painter's (less risk to damage the finished paint). To the point, the descriptions I read everywhere are that ..."the fender bolts are painted body color and undisturbed with the exception of those near the doors that were loosened to allow inserting the welting between the cowl and the fender". If the snap fixtures were placed later, then those bolts would also be disturbed, right?
    Concerning the clear coat, I would doubt that the factory would bother to apply it to where it wasn't needed, but maybe a light coat to protect the paint?
    For the door, I thought the black went all the way around, am I wrong?
    ____o0o____
    The snap fixture bolts were not painted. Yes, the black goes all around the door.
    Jul 2006
    Switzerland
    Where do we got the info that a clear coat was applied?
    I dont recall reading it anywhere.
    Moito might did this to his car but cant find proof the factory did.
    Metallic paint was expensive and as we know the coat went yellow over time.
    All I know front trunks were sprayed lightly in body color matt, like mine.
    Proofs pls? edmayo?
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by 911T1971 View Post
    Proofs pls? edmayo?
    not the colour went yellow its the clearcoat that was not much UV resisstant..
    ...and i actually even confirmed your observation of matt trunk.
    and of course they did not apply a full layer of clear in the trunk not even full layer of base.
    have a look at the factory vids you can find on youtube that show the painting of the trunk.
