Results 1 to 7 of 7
Thread: Rivets on door pocket hinges - source?
    Nov 2016
    Munich, Germany
    Hi all!
    I am considering giving my door pockets a nice make-over and redo the vinyl.
    To properly do so I would have to remove the rivets of the plastic hinges (at least on the front pockets).
    I know that there are sets being offered from numerous distributors. But all of them use simple pop rivets instead of the original tubular ones.
    Does anyone know a source for replacement rivets that come at least halfway close to the originals?
    thx,
    Tom
    --edit--
    I am not an expert on rivets but as much as I could find out yet the best matching rivets should be called "semi-tubular" and should be fitted in a "ring-rolling" way.
    Has anyone drilled-out the rivets yet and can give me the necessary dimensions?
    I'd guess the diameters should be something like head ~5/16" (7,94 mm), shaft ~5/32" (3,97 mm). Any confirmation on this?
    Nov 2016
    Munich, Germany
    I just tried the first set of rivets I found up on ebay:
    http://www.ebay.de/itm/125-St-Ø-9mm-...E/182097776986
    They do have a 9mm head (though not completely flat), the base is ~7mm and they are somewhat black.
    The color does not match exactly - at least by judging from the left-over paint on the og rivets - and they slightly differ in the shape of the head, but they come pretty close.
    Anyway, much better than using those standard pop-rivets, IMHO.
Size:  88.7 KBName:  IMG_20171211_133520_1.jpg
    Nov 2016
    Munich, Germany
    BTW, I also found a set of glassfiber pockets on ebay's classifieds here in Germany:
    https://www.ebay-kleinanzeigen.de/s-...17897-223-1125
    Though the seller only offers the folding pockets in the listing he also does the front map pockets.
    The below pictured set (L+R) was ~100€. Well worth a try to do the vinyl job by myself. Thank god a very good friend of mine does flock ;-)
    OK, it is not "the real thing", but neither are those aftermarket pocket sets being offered everywhere.
Size:  65.6 KBName:  IMG_20171211_135626.jpg
    Feb 2014
    Austin, TX
    Please post a photo of the fiberglass pockets after you get them covered with vinyl as this material makes much more sense to me than the original paper-board, as long as the end product looks good.
    '73 RoW 911T (project)
    '77 911S
    Early911SReg #2945
    Nov 2016
    Munich, Germany
    Wilco!
    Might take a little while though. I need to get more of the correct vinyl first.
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Tom,
    you know the gotoguy
    Nov 2016
    Munich, Germany
    Dirk,
    already talked to the gotoguy ;-)
