Results 1 to 9 of 9
Thread: SWB inside cabin paint, undercoat and caulking/sealer details
    Spend quite some time today with my painter going over the car. Metal work is done aside from some final metal finishing so we are getting closer to paint. To ensure an as authentic job as possible we are trying to document some details. Hoping with help from others we can maybe turn this into the ultimate SWB paint detail thread.
    Below is my hypotheses on what the factory did based on observations from my December '65 car. I have written it in what I think was the chronological order of application
    - Caulking in selected areas, on my car I see caulking about 1" wide which appears to have been applied by brush all around the steering shaft tray (have no better way to describe this) and some in the foot well area
    - Application of undercoating (coarse texture) the whole back part of the car, floors, inside lognitudinals with some over spray coverage on the vertical services in the foot well area. areas like tunnel, seat stands, and pivot area for rear seats likely masked off
    - Application of light grey primer (primer color probably dependent on color of the car) on top and vertical surfaces of dash and under dashboard area same for A-pillars and likely roof
    - Application of body color in the whole cabin. Unsure if the whole dash was painted body color or just the dash top and the edges of the dash from the over spray from the door opening area and A pillars
    - Application of flat black paint across the dash, underneath the dash, tunnel, seat stands and center pivot area for rear seats
    Curious to learn what others have found. Would also love to see factory pictures of the SWB painting process if anybody has these to check the above.
    JK
    I have searched through the archives a bit and have found some interesting posts. Most focus more on the outside of the car but I will tag them on with the intention of creating one post which captures all SWB paint details
    http://www.early911sregistry.org/for...ghlight=sealer Some good undercoating information by 304065
    http://www.early911sregistry.org/for...ghlight=sealer Topic focussed on undercoating
    http://www.early911sregistry.org/for...ghlight=sealer So far the most detailled thread I have been able to find on the topic
    http://www.early911sregistry.org/for...ghlight=sealer Discussion if the schutz was applied over bare metal or not. Yes for SWB seems to be the consensus and is what I have found on my car, no for LWB cars
    Interesting picture I found on a different thread. No idea of the publication or date
    Some pictures of my car showing the grey primer, sloppy coverage underneath the dash and seam sealer. Excuse the poor picture quality
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Im not too sure on this
    However i can confirm that the "brush" got slapped around a bit back then.
    Mark
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by 718RSK View Post
    thats a still taken from a factory doku film ....can be found on youtube
    Found this online. Not the same video I think but intersting. Its a consolidation of several factory movies. SWB cars start around the 5 minute mark. Would be very interesting to find the whole video
    https://www.youtube.com/watch?v=K4AXW4l55T8
    May 2013
    AUSTRIA (tu felix)
    plus all the material that was filmed but not used...
    absolutely, the same goes for the edited out parts of made by hand
