Results 1 to 10 of 10
Thread: 75 911S CIS help
    Aug 2016
    Eastern North Carolina
    75 911S CIS help
    Car won't start. Repeated attempts result in backfire. Blowoff valve bolwn off. Fuel pump works. Ran fine last time run. Recently replaced injectors.
    Probst Troubleshooting guide suggests cold start enrichment valve or thermo time switch may cause this? My factory manual is 1973 and doesn't seem to match the 75 S K basic CIS?
    Any help, suggestions, diagrams etc. is appreciated
    Thanks jfd
    Post says "blow off valve blown off". If that's the case, then your car won't start because you have no vacuum, to lift the sensor plate.
    Aug 2016
    75 911s cis help
    Quote Originally Posted by Rick Cabell View Post
    Thanks Rick. What made it blow?
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    A backfire through the intake
    1969 S Coupe #761
    Early S Registry #1624
    Peter Kane
    '72 911S Targa
    Banned
    Nov 2004
    Scottsdale, AZ
    Is this a trick?
    Be glad you have the tiny toilet seat otherwise I would have to sell you a new air box which I have several of.
    Glue it back in and check your mixture.
    Aug 2016
    Thanks guys
    Not a trick. Just never had it happen before and trying to find out why it happened. Thanks for the tips
    Start here http://jimsbasementworkshop.com/CIS/
    Could be anything based on your description.
    Aug 2016
    Thanks Jsottile
    Very informative site
    jfd
    Jun 2010
    CT US
    grounded/damaged plug wire.. crank crank crank turn key off loud backfire common with the CIS..
    also if the fuel reg is shot and not holding pressure it will never start either.. good luck CIS is more fun then MFI
