What were the full size spare options in 1972?
www.tcspeed.com
I'm a bit puzzled by the question. It would have been the same wheel that was on the car.
Full size spare was not an option.
normal Tank -> full size spare
big tank -> flat spare - > no optional full spare- wouldn't fit in anyway
My thought was that 1972 was the first year Porsche offered a choice of "Alloy" wheels on the cars. (late 1966 you option up to Fuch from Steel wheels)
Base model T and E came stock with the cookie cutter's and clients could 'option up' to Fuch.
I am sure you could have saved about $5 back then and asked for a cookie as a spare for your 4 Fuch but I doubt anyone would have been so crass.
As previously mentioned by Dirk if you opted for the larger fuel tank ( I dont know what that option number is ) a full size spare would not fit and you would have been fitted with the space saver style spare wheel of steel.
Mark
my 1972T has a steel 15x5.5" wheel as the spare.
Would it be correct? Or from another car?
www.tcspeed.com
72
standard 5 wheels of the following dimension/material
T: steel 5,5*15"
E: steel 6*15"
S: Fuchs alloy 6*15
option for T: 5,5*14 , 6*15" steel or alloy
option for E: 6*15" alloy
www.tcspeed.com
my spare is dated 1970. Would that be typical date used in a 1970-1973 911T for a spare? Or are the dates matching the production date of the car?
www.tcspeed.com
No, it wouldn't be correct. If your 72 came with steel wheels, they would have been 6 X 15 and the spare would have been the same size. 72 was the only year where a 6" wide steel wheel was offered, and it was the base wheel. 73 911s had a 6 X 15 cookie cutter as the base wheel and it would have come with 5 of them. 74 911s came with a space saver on a
5 1/2 X 15 steel wheel as the spare. The first year that used a different wheel for a spare. 73 911RS and RSRs excluded.
Ciao
Jim
