Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: 65/66 911 outer side rocker panels
  1. #11
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    Filled after paint to glue the rubber boarding strip to get a larger surface for fixation?
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
  2. #12
    Sounds logic your interpretation to fill them up so the rubber board has more surface to provide with glue.
    So we can say that the rocker panel needs the indents to be correct.
    And like Franz says they where filled up after the car was sprayed.
    So when removing the rubber you see some white square filled up areas.
    What would you guys advice for the restoration?
    Thanks!
Tags for this Thread
