Results 1 to 7 of 7
Thread: 915 shift knob - please help identify original vs. repop
    Senior Member damsroy's Avatar
    Jun 2007
    Connecticut
    How do you tell the difference between an original and a Reproduction?
    The one pictured below is in Bakelite but has the bottom squared off when the NOS one I once had had a more rounded bottom? Been told it came from a 74. Is there a difference for shift knob between 72/73 and 74 onward?
    Early 911 S Registry member #3308
    911E 1973 - Brownie- 66k original miles - Second owner
    911E 1971 - gold metallic - sold and missed
    912 1966 - sold
    As a point of reference, here's my original ('73MY) patina knob . . .
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
    Early 911S Registry #548
    Jun 2007
    Connecticut
    Thanks Doug. Does it have a rounded bottom or more of a squared off bottom? Looks square but Hard to tell on the pictures.
    912 1966 - sold
    Jul 2011
    Chicago Area
    I would bet that Doug's original has a rounded bottom rim, also your numbers 3 & 5 and the letter "R" are completely different. You should be able to see an equator line around the grip/round top, like Doug's has. Flat rim is only on Repro's in my opinion, I would bet it is not Bakelite material either.
    Side by side below:
Size:  60.6 KBName:  knob2.jpg
    Mike Fitton # 2071
    2018 911S Carrera White
    Based on Mike's side by side comparison - the fonts are definitely different.
    Here is a couple more shots of the bottom, hope you can determine from these . . . focus is poor.
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
    Jul 2011
    Chicago Area
    Quote Originally Posted by DOUGS73E View Post
    Yep it is rounded, also see the faint equator line in this picture of Doug's. It is always there on original knobs.
    Mike Fitton # 2071
    Jun 2007
    Connecticut
    I added a pic of an NOS one to compare the font. The font on NOS looks similar to Doug's.
    912 1966 - sold
