Results 1 to 7 of 7
Thread: Help with 911S VIN
    Jan 2018
    Help with 911S VIN
    Looking at a 1968 911
    here is the VIN
    11835XXX
    Is this a 911S? i am confused because it would have to have been imported. Dont have and engine number yet.
    Any help would be appreciated.
    Mar 2007
    Melbourne, AUS
    According to the identification site I always go to (elferhelfer.de), this should be a 1968 911 Coupe, not an 'S'.
    As in "11" identifies "model 911", 8 referring to "1968 model year, not always production year", "3" referring to a "coupe", whereas a "0" there would have made it an "S coupe".
    That site also states that if the last 4 digits start with a "5" (like in your case, It would be a chassis produced at Karmann.
    Cheers, Patrick
    Mar 2007
    Melbourne, AUS
    btw, that site also indicates that the engine number for this model should be between "3080001" and "3080655".
    http://elferhelfer.de/fz-ident/1968.html
    If it is, it is more likely (but not guaranteed) that the engine is original to the car. Only a certificate of Originality (CoA) by Porsche can confirm that.
    Jan 2018
    Thanks! It is a Karman coupe if that helps
    Senior Member HughH's Avatar
    Melbourne Australia
    Patrick is correct
    11835xxx is a USA 911 Coupe made by Karmann
    HOWEVER all the ones i have data on have engine numbers in the 328xxxx or 338xxxx as confirmed in numerous cases by Kardexes
    transmissions are 308xxxx 902/0, 318xxxx 905/00, and 328xxxx 902/1
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Jan 2017
    NY/VT
    Sent you a PM. My former 1969 S coupe was 119300141, 11=911 9=1969 3=S 0=coupe 0141=sequence.
    Melbourne Australia
    NYSport
    the 68 numbering sequences were quite different and the S's had a 0 rather than a 3 identifying them as in later years - makes it confusing at first glance. Also the Karmann ones are not easily identified as they have the 5 in the fifth digit - a digit used only for serial number on all other cars in 1968
    here is the appropriate page in the spec book
    Hugh Hodges
    73 911E
    Melbourne Australia
