Results 1 to 10 of 11
Thread: Correct nut for SWB Boge strut inserts
    Senior Member Robert-Jean's Avatar
    Feb 2008
    Netherlands
    Hello guys,
    Which nut would be correct for Boge strut on a 1966?
    thank you.
    Robert
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Robert-Jean View Post
    Hello guys,
    thank you.
    Robert
    The one on the left is for a Koni shock and the one on the right is for a Boge Shock. The Boge nut is more correct. Your Boge struts should be painted blue/grey not black.
    Jim
    Jim, isn't the thread pitch also different from Koni to Boge?
    Aug 2009
    SF Bay Area
    Ed
    Yes, the thread is different on SWB Koni struts (the tube is larger at the top on the Koni) vs the Boge. The picture shows 2 Boge struts. One with a Koni insert (made for a Boge strut) and one with a stock Boge insert.
    Jim
    Thanks Jim, I knew I had run across different thread nuts.
    Aug 2011
    Virginia Beach Va
    Jim
    Could someone Please show us the Blue Grey color you speak of
    Thank you
    Doug Lehman
    Member #2825
    1966 912
    1978 911SC Targa fun in the sun
    Feb 2013
    Europe
    For which years the Boge blue/grey would be applicable? For a 72/73 I have, I was convinced (sofar) the Boge strut was original and black.
    Don't want to speak for Jim, but I think he meant to say the inserts themselves are blue/grey color...
    John Schiavone
    Connecticut
    Aug 2009
    SF Bay Area
    Quote Originally Posted by John912 View Post
    The inserts were blue/grey. as well. I was referring to the outside, though. The strut tube and the dust shield were blue/grey. The base that holds the ball joint is painted black.
    These are for "SWB" 911s and 912s. The blue/grey color is hard to find as virtually all struts are covered with crud and underseal.
    Jim
    Aug 2011
    Virginia Beach Va
    Thanks Jim I knew you would have one box those
    Doug Lehman
    Member #2825
    1966 912
