Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Axle sealing ring?
  1. #21
    Senior Member MikeyC's Avatar
    Nov 2015
    Oxfordshire, UK
    A possible solution for this NLA seal:
    For the benefit of others who may have found their way to this page, a possible (and very readily available) solution for this NLA seal is the larger of the 3 oil cooler/oil pump o-ring seals, 99970417350. Being a square-section seal 26mm OD x 19.5mm ID x 8.5mm tall, it has an ideal 3.25mm square-section wall thickness and stretches out to 30mm ID quite readily.
    With a small amount of axial compression as the axle shaft bolts up to the hub, it allows the seal to bulge slightly on assembly, creating a light compression fit between the axle shaft and the inner bearing race. Both these parts rotate together with the shaft so there is no risk of rubbing contact wear between the seal and it's mating faces. See cross-sectional view of seal in-situ, labelled '11':
    Mikey C. ESR Membership #3333
    http://www.mceporsche.com
  2. #22
    I like that kind of problem solving!
