Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
Thread: Fuel Line Sizing
  1. #11
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    1969 S Coupe #761
    Early S Registry #1624
  2. #12
    Banned
    Nov 2004
    Scottsdale, AZ
    Bryce,
    I read it.
    Call me slow witted but still not understanding the comment
    10mm or 5/16”.
  3. #13
    Apr 2012
    Santa Clara, CA
    Bryce and Frank- Thanks for weighing in and for leading me to the other thread. I am ordering up the smooth Cohline lines in the appropriate size (7.3) and the porsche line in 9mm. I will also order some clamps. Appreciate all the help.
  4. #14
    Dec 2008
    Black Mountain, NC
    Sorry Frank, meant 8mm or 5/16" hose, basically the same fit in rubber hose depending what is available.
    Bryce,
    I read it.
    10mm or 5/16”.
  5. #15
    Banned
    Nov 2004
    Scottsdale, AZ
    Quote Originally Posted by Jerry L View Post
    No worries. Anymore I assume I'm the one who is confused.
  6. #16
    There are a great many threads on Pelican. Here is one, with input from our departed friends Grady Clay and Warren Hall: http://forums.pelicanparts.com/porsc...72t-mfi-2.html
    Use Cohline hose, the original manufacturer, in original metric sizes, not inch hose from anyone else.
  7. #17
    We have had very poor results with Cohline 2122 and Ethanol containing fuels and tried to resolve the problems we had over a period of 2-3 years.
    It started to weep and leak after around 8 months with the car developing a very strong smell of fuel whilst garaged. Cohline advised that the engine bay temperatures in a 911 were probably greater then the 50degC rating of this hose and considered our concerns to be invalid. This hose pictured below was 8 months old and the car had been driven for about 50 miles during this time.
    We also fitted Cohline 2122 to a 1967 'S' used in France with E85 fuel and the hose lasted 3 months before it failed.
    We now use a hose manufactured in Denmark - Brand Name Codan 3106 - and this has been good for the last two years
  8. #18
    Oct 2004
    SW Suburbs of Chicago
    Googled Codan 3106 and looks good, but noticed "Must not be used in cars with injection systems". Hmmm...thoughts?
    https://www2.codan.com/node/28212
    Mike O'Meara
    Reg #1043
    72 911T
    56,59 356s gone
    67,68 912s gone
  9. #19
    I am sure that this is more concerned with K Jetronic or EFI Systems which run much higher pressure than an MFI.
    An MFI runs between 1 and 2 bar and the Codan is rated at 13 bar max. operating pressure and 50 bar burst pressure.
    Cohline 2122 is typically rated at max. operating pressure of 7 bar and burst pressure of 30 bar.
  10. #20
    Quote Originally Posted by chris_seven View Post
    Chris, of course 2122 is only good for up to 10% ethanol. E85 would most certainly go right through it.
