Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
Thread: Mirror Experts - Please chime in
  1. #31
    If you're looking to replace the glass in your large Durant, the glass from a Velvac 708520 mirror will fit.
    https://www.finditparts.com/products.../velvac-708520
    It takes a light touch to remove the Velvac mirror from the housing but once you do it's pretty much plug 'n play. One note, the Velvac glass is slightly convex so it's not technically 100% correct but I can't imagine anyone would notice by looking at the car and I like the slightly wider view it provides.
    Hope this helps.
  2. #32
    I've replaced the mirror in a Durant by getting the black retaining ring out and having the local glass place cut a new one. Just need to make sure they use the thicker mirror stock to match the original thickness.
  3. #33
    Senior Member BrentF's Avatar
    Sep 2012
    Toronto
    I vote real.
    I've also had good success replacing the mirror. The black plastic ring that holds the mirror in place is a friction fit. It can be delicately pried out with a flat head screwdriver or similar device, by gradually working your way around the circumference of the ring. Replacing the ring, simply involves pressing down on he ring until it properly seats in the metal housing.
    I had my new mirror cut at the local glass store. I think it cost me $5.00?
    Brent
    '70 911S
    '68 TR250
  4. #34
    See reference in the 911T 'For Sale' thread . . .
    http://www.early911sregistry.org/for...l=1#post997297
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
    Early 911S Registry #548
  5. #35
    Aug 2009
    SF Bay Area
    ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Phony as a $3.00 bill
  6. #36
    Dec 2013
    Connecticut/Florida
    Jim,
    This is fake correct ?
    1971 911S Coupe - Gemini Blue
  7. #37
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Simonjjb View Post
    Jim,
    Very much so!
  8. #38
    Jan 2007
    North of the GG Bridge
    As a guide for myself I added the reference lines, perhaps this helps.
    Note: Original photo from post #13 this thread.
  9. #39
    Ok
    What do ya'll think of this one?
    Zed
