Page 7 of 15 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 148
Thread: 1969 912 reSee Works Build
  1. #61
  2. #62
  3. #63
  4. #64
  5. #65
  6. #66
    Feb 2005
    Lake Tapps, WA
    Beautiful! All these little tricks will add up to a huge difference in oil temps
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
  7. #67
    cutting centre out and the plan is to replace with crimped stainless mesh.
  8. #68
    Adding a fan to assist cooling temps in slow to standing traffic.
    square bead work to flow with factory pressings.
    Fan bolted in position,and patterning for air flow deflector shield to maximize cooling.
    mock up aluminum ,advancing from cardboard,chopping and changing to dial in
  9. #69
    Aug 2010
    Colorado
    That little fan is a 3 phase fan and can take 25 amps. We'll only run 8 to 10 amps through it. It's used for radio controlled hovercraft. At 5 amps it shoots around on the floor. Jon has designed baffling to direct air through, over, under, and to the outside of the battery box when the car is moving. The whole cooler will get air flow. The fan is for stop and go city driving.
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
  10. #70
    setting up oil cooler lines
    lower air scoop build
    Mocking up the upper air flow scoop which covers 40% of the oil cooler.Roughing out first in cardboard,then alum
