Thread: Any CIS 1976/77 specialist here
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Looking for some information on CIS WUR 76/77 3,0 Carrera.
    Wonder if there had been a change of the WUR (033) from 76 to 77, when the AAR was introduced.
    BR
    Dirk
    Most of those are on Pelican Parts.
    There are several very knowledgeable guys.
    I had good information re my 73.5 CIS...
    Think it’s very similar to yours
    What’s issues are you having?
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Apr 2016
    Stuttgart, Germany
    Thanks got the issues solved.
    My question was, if there had been a change of the warm up regulator from MY76 to MY77, when the thermo-valve in the vacuum hose to the wur was introduced.
    The answer is: YES, the WUR had been changed from 76 to 77, when the thermo-valve and the AAR had been introduced.
    But the only difference was the internal resister of the electrical heat up. 76 (017) hat 35 ohms, 77(033) had 26 ohms.
    Porsche realized the issue with the individual heat up of the upper and lower (by engine) chamber of the wur and changed the WUR ports for MY 78. So for MY78 the 045 was introduced (but will not fit 3,0 Carrera) with a vacuum inlet on the side, which is internally connected to the already by the engine heated lower chamber.
