Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 61
Thread: SWB 1968 - Best way to mount a period correct 3 points harness ?
  1. #41
    Mounting plates are readily available from a number of sources. I bought mine from another earlysreg member based oug of New Zealand. The template i can send via email
    Mark
  2. #42
    Try "advracing"
  3. #43
  4. #44
    Feb 2005
    Lake Tapps, WA
    You could also mount to a roll bar cross bar. Not that I'm a fan of that, but it is an option.
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
  5. #45
    Aug 2012
    France
    Thank you all.
    Quote Originally Posted by Mark111 View Post
    Try "advracing"
    I did order some parts from, and it is great source indeed.
    Quote Originally Posted by Bill Simmeth View Post
    Thank you for the link.
    Quote Originally Posted by endo911rs View Post
    Good suggestion - although not period correct and am no fan.
    O-G 26 - Early911S 2407
  6. #46
    Aug 2012
    France
    Found that cool plugs setup on a french forum. Have asked for more details.
  7. #47
    What a great inspiration and source this forum is!
    I'd been thinking to install period correct racing harnesses for quite a while but didn't know where and how to mount it. Now thanks to the information on the '68 mouting holes on the shelf I started digging and found them. Gonna get the Britax 3 Point harness straight away
Size:  59.4 KBName:  IMG_9324.jpg
Size:  98.8 KBName:  IMG_9326.jpg
    Thanks to everybody!
    LOOKING FOR SERVICE BOOK No 2361
    1968 Karmann Coupe 2.0 tangerine
    1993 Ducati 750 SS
  8. #48
    Apr 2008
    Virginia's Blue Ridge
    Quote Originally Posted by Trainee Fritz View Post
    Best post in a while! Thanks!
  9. #49
    Everything installed now - 3 point Britax harness fixed to parcel shelf mounting holes. Quite tight compared to the previously installed 3 point static belts, but I'l get used to it!
Size:  78.1 KBName:  IMG_9370.jpg
    1993 Ducati 750 SS
  10. #50
    Mbr 3268 Fixer's Avatar
    Jun 2015
    Philadelphia area
    I did the same with my 68.
    Matthew J. Mariani BSID, Member 32689
    Haverford Pennsylvania
