Thread: Lighter
    Junior Member
    Apr 2018
    Baltimore
    Lighter
    Hello, can anyone give some information about this cigarette lighter? I've never seen one before and I've owned it for close to 30 years, it was originally on a 68' 911 I owned. Hands free lighting of a cigarette while driving... Place the cigarette in the hole, push down on the perimeter collar and it lights. There is a heating element in the base, has an automatic turn off when it reaches the right temperature. years ago a friend told me it was a "racing" lighter but I have a hard time believing someone would try to light up going down a strait at 130+ ... Here's a pic. Thanks for the input.
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    I had an Alfa 105 1750 that had a lighter like that installed in it. just to the rear of the gearshift and facing upwards.
    Dont think this would work on a 911 as the lighter is mounted vertical and the ciggie would just fall out
    M2CW
    Mark
    Junior Member
    Apr 2018
    Baltimore
    You would think it wouldn't work but it did, I tried it when it was installed in the car... I doubt if it was a factory option though, probably dealer installed.
    Nov 2016
    Munich, Germany
    Thank you. Now I want one.
    Crazy prices though...
    BTW, they are called "Brico Pram" and were used on Alfas and Ferraris (and probably others) back in the days. The nicest feature is a tiny little gong when the ciggie is lit.
    Brico Pram
    Quote Originally Posted by tomster View Post
    . . . called "Brico Pram" and were used on Alfas and Ferraris (and probably others) back in the days. The nicest feature is a tiny little gong when the ciggie is lit . . .
    . . . and I don't even smoke
Tags for this Thread
