Results 1 to 7 of 7
Thread: shift spring install
    I've noticed that installing these lock out springs seem to cause people problems, so I've finally remembered to take pictures when I did this recently. Use two long skinny punches, use one to hold the plate in place, stick the spring in the housing arched up, stick punch in, straighten spring and poke punch out other side, push retaining pin in as you pull punch out, attach e-clips. No flying springs!
    Sep 2009
    Good post with great pictures Ed. That job can take an eye out...!
    Dave
    Aug 2010
    Thanks Ed
    Chris
    South Carolina
    Yup that’s how I did mine
    Apr 2011
    N.Calif., south of SF
    My nose still aches ..... from the last time I attempted this. Thanks Ed great way to do it.
    Yes, the good news was the launched spring just hit the end of my nose ....<script type="text/javascript" src="safari-extension://com.ebay.safari.myebaymanager-QYHMMGCMJR/68d4138a/background/helpers/prefilterHelper.js"></script><script type="text/javascript" src="safari-extension://com.ebay.safari.myebaymanager-QYHMMGCMJR/68d4138a/background/helpers/prefilterHelper.js"></script>
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    And this saves grinding up a screwdriver! (And drinking one, too!)
    http://www.early911sregistry.org/for...ng-replacement
    1966 911 #304065 Irischgruen
    May 2011
    Chelsea, Québec
    That’s what I used... thanks for the original tip!
    Quote Originally Posted by 304065 View Post
    Member #1616
