Results 1 to 9 of 9
Thread: WTB: Pair of 73 rear tail lens side marker diffusers + Lens spacer washers
    I need two clean non-cracked diffusers for the left and right rear side marker lamps.
    Look like these:
    And also have you smart folks sourced the lens spacer washers on the screws? I have good screws, just need 12 of the washers. They were forgotten many times over by the PO.
    Washers needed:
    Thank you!
    Dave
    The Netherlands
    Reflector you show looks like an ROW front one, or am I wrong?
    Cees
    Yes, thank you. Photo was for reference only.
    I have a US 1973 and need two rears, as mine are missing.
    The Netherlands
    All right, unfortunately I only have the fronts available.
    Good luck with your search.
    Ces
    You an find those lenses from Sierra Madre:
    http://www.sierramadrecollection.com...88-p31930.html
    The Netherlands
    The SMC is not correct for US version rear housing. The one advertised is glued in place and much thinner than the US version which is removable because there is a light bulb behind the reflector.
    Cees
    Anyone else have these? Someone has to have pulled them out of a race car! #loose-weight
    May 2006
    CT
    Hi Dave
    I have this pair. Email me if interested.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    I have them as well if you are still in need of them.
    Erik - (303) 443-1343 ext 2
