Looking forward to seeing the front and rear side reflectors!
Peter Kane
'72 911S Targa
Not knowledgeable enough to talk with authority, but this is a baseline coupe with aluminum dash. The tach is the appropriate color and if its really a 66-67 then would be green face with chrome trim ring. May have been redone but I suspect just a lesser tach for the lower priced model. Real experts please chime in. Also for aesthetics I would keep one Torino and redo it in basketweave and make the passenger seat a comfort seat. Would have been an appropriate dealer mod. And for whatever its worth my April 30th 912 coupe had light ivory headliner
68 models hat black instruments... you also see it at the brider ash tray handle ;-)
best
the correct wort is : wider
nice car--the windshield has the sun shade section at the top; not found on original cars from the period. Chris
- Chris-Early S Registry#205
- '70 911S Tangerine
- '68 911L Euro Ossi Blue
Clyde Boyer
Early S Registry Member #294
TYP 901 Register Inc #6
Re the tacho
I don't think it has been re done, it is black and white but has the metal circle which indicates pre 68
Guess I have to pull it out to check the date on it and that may provide the answers.
Clyde Boyer
Hi Clyde-- Do you mean the grey felt type carpet most early cars have in the trunk? Chris
Yes the perlon.
Trying to figure out where the cuts are for the brake fluid resevoir and over the shocks
Clyde Boyer
