Results 1 to 7 of 7
Thread: 230 MoMo Hub
    230 MoMo Hub
    I have a 230 hub that I tried to install on my '73 911. The hub splines are very tight. Even with a bit of force it will not go on. Is it possible the 230 hub is only for SWB cars? Any insight is appreciated.
    Dean
    May 2009
    West LA
    Not sure why you are struggling to fit the hub but I can tell you that I have a 230 hub installed on each of my LWB cars so compatibility is not the issue.
    Registry Member #1583
    Please share some pictures...
    Peter Kane
    '72 911S Targa
    Had this issue couple weeks ago. I ended up buying 3 of them all tight. Use a rubber mallet and give it a little love tap. slipped right on.
    btw i have extra hubs now if anyone wants.
    I thought about giving the hub a tap but was concerned I would not get the 230 back off. I even tried a bit of lubricant but it is really snug. Latter I tried a Nardi and it worked just fine. Peter, can you be specific as to what pictures you want to see?
    Thank you!
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    Maybe deburr the splines with the proper file?
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    Fenixv8 I sent you a P/M.
    Thank you!
