Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: 1972 Paint Code Plate - Help Please
    My brain is on fire... Too much to do and too little time to do it in.
    Can y'all help me out with the correct digits on what the paint code plate is supposed to say?
    1972 Light Ivory (131) Car is a coupe
    Soooo it would be 131-?-?
    Stuart Zeh
    sezme@aol.com
    Senior Member karlusmagnus's Avatar
    Aug 2005
    NY
    The Glasurit code would be 6804 for Light Ivory (HELLELFENBEIN)
    on an earlier thread it was stated
    "that's the correct paint number:
    8080 is for Coupe models
    8010 is for Targa models
    Up to '71 the plate on the driver's side hinge post shows the paint number & paint manufacturer - not the paint code."
    and then Karim stated in answer to Roger Gargo's question "What is the difference between paint number and paint code?"
    that Paternie's book stated "As of C-Series 1970, the factory changed to four digits, the last two digits for TARGAS end in "10".
    -paint number (sometimes referred as paint code as well) is the number stamped on the metal plate on the chassis.
    light ivory: 1110/1111, olive: 3910/3939, tangerine: 2310/2323
    -paint code is the code of a color chart list.
    light ivory: 131, olive: 414, tangerine: 018"
    Karl: E911SR #792 ; RG #420 ; GS #7
    '72T Coupe - Sepia Brown
    Stu:
    My light yellow 72T plate has 117-9-1, and the 72 Kremer ST ReC has 415-9-2 (orig. Sepia). I think the silver 72S had a plate that was 936-9-2. The last digit indicates the paint manufacturer...1 Lesonal, 2 Glasurit...I think. Not sure what the 9 is for.
    Gib
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    The correct form for the paint code on the badge from 1972 through 1983 is xxx-y-z where xxx is the paint number, y is the body manufacturer, and z is the paint supplier.
    3 is for Herberts
    Quote Originally Posted by karlusmagnus View Post
    Aren't the codes thet you are referring to only accurate for cars prior to 1971/72?
    Stuart Zeh
    sezme@aol.com
    So mine would be 131-9-2
    131 = light ivory
    9 = Porsche
    2 = Glasurit
    Right?!
    Stuart Zeh
    sezme@aol.com
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    Stu, the coachbuilder is Reutter.
    RGruppe #183
    Don't mess with me Jens! Are you still living in Stowe?
    Stuart Zeh
    sezme@aol.com
    Aug 2003
    vahmont
    I think Lechler is the company that made Lesonol paint products, Herberts made Herbol paints, and Glasurit made Glasurit.
    RGruppe #183
    Aug 2003
    vahmont
    Yeah Stu, it's a good place to be.
    RGruppe #183
  1. Paint Code Plate Font?
    By Irish911 in forum Technical Info
    Last Post: 02-11-2013, 05:15 PM
  2. Wanted: paint code plate w/ Conda green code
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 11-05-2009, 07:33 PM
  3. 1972 Paint Code Plate - Help Please
    By sezme in forum Technical Info
    Last Post: 04-23-2009, 05:34 PM
  4. how do I remove paint from paint code plate?
    By 911scfanatic in forum Technical Info
    Last Post: 10-26-2005, 06:00 AM
  5. Paint code plate reinstallation question
    By neilk in forum General Info
    Last Post: 05-11-2004, 06:57 PM
