Results 1 to 10 of 10
Thread: Correct paint for KONI shocks and struts?
    36 year PCA member
    Dec 2012
    Denver Co.
    Something that is easily available. Also correct decals for 67 model year? Thank you.
    Apr 2012
    Simi Valley Ca
    I believe Chevy engine block orange is very close.
    Bob B
    http://www.early911sregistry.org/for...S-front-struts
    for the early cars it seems to be a reddish brown color
    Do we have the definitive answer? RAL colour?
    Senior Member moito's Avatar
    AUSTRIA (tu felix)
    Quote Originally Posted by Toffynose View Post
    not sure about the struts but the koni steering damper is ral 3016 coral red
    AUSTRIA (tu felix)
    Quote Originally Posted by stretch View Post
    I used Ral 2002.
    thats todays koni colour i think..is it?
    Sep 2009
    No, It's not the Red. It is the German code for "blut Orange"
    [ATTACH=CONFIG]460285
    The original "early" Koni orange is a brown-ish red. The closest out of the can would be a red oxide primer with clear coat. I had original factory Konis on my '69 011T, and I had my local paint supplier do a custom color match. Here are photos of an original date stamped '65 factory supplied Koni. Note the "PORSCHE" stamp and date stamp...also I have never seen decals on original early factory Konis. The decals came along later as an after market item, or on replacement Koni units, and they have taken on a life of their own.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Nov 2006
    S. F. Bay Area
    Yes. ^^^^^
    Much closer to the color found on the heater flapper valves.
    A touch up spray can of Porsche "Peru Red" is very, very close.
    Brian
    S Reg #1032
