Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: WTB: MotoMeter Celsius Oil Temperature Gauge
  1. #21
    May 2005
    Southern California
    Located a really early Motometer here in the U.S. Thank you Fred!
    Same temp-range (40-120 Celsius), but the dial face and bezel should both be black
    Nearly the same style needle (bottom tail flares out, is wider on the 917K gauge)
    60mm can-size, the same as the gauge used in the 917K
    A really early NOS sample, December 1956
    12 volts, 2W bulbs...
    I'm keeping it...
  2. #22
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    The motometer should be doable to find in Germany.
    Bingo!
  3. #23
