Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Heat affected rear license panel paint
    After a recent engine rebuild (maybe not related) the paint on my rear licence plate panel has begun to blister and it does seem much hotter
    to touch than previous.
    Does the muffler have some sort of internal heat shield that might have stopped being effective as I think the muffler is quite old?
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Maybe not stock, but I think I put some aluminized type insulation there.
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
Size:  51.5 KBlike this?
    Aug 2017
    el sobrante ca.
    A long time ago …. I had that happen … brand new paint job …. The car was then tuned perfectly and it never happened again …. It was a 1972 mechanical injection car..
    Quote Originally Posted by dirk07 View Post
    Yes identical to that, even the same colour!!!
    What has tuning got to do with heat at the back end??
    Clyde Boyer
    Apr 2011
    N.Calif., south of SF
    I believe the later cars had an aluminized piece that attached to the inner side of the license plate panel. Sorry, don't have any further info.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Dec 2011
    Palm Coast, FL.
    You could try something like this https://www.summitracing.com/parts/t...iABEgL3FvD_BwE
    ESR # 2300
    A very good friend who raced a lot added some very cool louvers to his license panel...
    If the ignition is retarded it can run hot.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
    This is/was a common problem on '73 and earlier cars...especially cars with sport mufflers or cars used on the track. The solution is simple. Take off your bumperettes and rear license panel and the rubber seal across the top. Then take a piece of aluminum (tin works too) the width of the license panel and about 6-8" down. It should be thick enough to be rigid but thin enough to bend. Your local hardware store will have something. Attach it to the area on the chassis approximately where the license panel seal sits. Pop rivets or sheet metal screws both work. Pre-bend it to curve over the top of the muffler and down to about the mid point in the muffler (approximately where the muffler seam is should be enough). It should rest approximately a 1/2" away from the muffler and but not touch the license panel. This will give you a heat shield between the muffler and your rear license panel. When you re-install your license panel it will be hidden and not seen but it will give you the heat protection you need. I've done this on several cars and never had a problem with paint burning or bubbling on the license panel again. I looked but unfortunately don't have a picture. If my description of what you need to make isn't clear enough let me know and I'll see what I can find.
