I used this product from Summit and it works very well, there is enough for two panels .
https://www.summitracing.com/parts/THE-16850
Clyde Boyer
Early S Registry Member #294
TYP 901 Register Inc #6
Thanks for all the heat shield suggestions if I can't get to the root of the issue then I guess this is a solution
Clyde Boyer
[ATTACH=CONFIG]462595[/ATTACH]
Thin aluminum attached with sheet metal screws.
That's all folks...
A shield can do the trick, but (high) heat transfers through aluminum easily. Similar to the stick on product, if a panel were 'jet coated' at the rear that result would work well.
My guess is when engine is broken in some the temp will drop. We now dyno all engines, it is the easy way to rule out problems, run the engine in, set mixtures and ignition. Then service the engine and install in the car.
in my case the overheating was caused by a leaking vacuum hose to the ignition distributor which lead to a retarded ignition
Interesting Dirk your the 2nd one to mention retarded ignition
I went for a drive tonight very cool air and a very hot licence plate panel.
Gordon we will see as over the next week probably going to rack up 1000km
Can't make it any worse than it is just need to see if I can isolate the cause
Clyde Boyer
Ok ok, in my case the respray was more likely done with a gold spray rattle can
other solution is shown in this thread#10
http://www.early911sregistry.org/for...ferrerid=29735
