Thread: Ignition switch bezel change from small to large bezel?
    Senior Member softwindow's Avatar
    Jan 2015
    Bonn, Germany
    Hallo experts,
    restoring my 302485 I´m not sure whether the small or large ignition switch bezel is right. Looking in the threads there is no exact VIN range for the change mentioned. The chassis is the old one without adjustable struts and the waterbag in the fender.
    Does the old chassis correspond with the small bezel?
    The car was first delivered to California.
    Greetings
    Anke
    356 A 58 silver
    302485 light ivory
    500248 Softwindow light ivory
    500441 Softwindow S light ivory
    2.2 S Targa geminiblue
    2.4 T Targa black
    2.4 S Targa vipergreen
    2.7 RSR tribute green (original 2.4 E 1972)
    Macan GTS black
    Boxter S black
    997 Turbo Cabriolet black
    BMW R 17
    BMW R 69S black with Steib 500
    Aug 2009
    SF Bay Area
    Anke
    It would help if you post a picture of your ign switch. That should give a good clue as to which bezel was used. My guess is that your car came with a locking switch which would have ben equipped with a brass bezel with a flat round plastic base.
    Oct 2008
    Burford, ON, Canada
    Based on the photos that I have collected it seems to be a 1965/1966 model year change that includes the change from straight knee pad to the U shaped one and paint code from 64xx to 66xx. This is still not exact, but perhaps a guide. Photo documentation is useful.
    Senior Member VA_alfa's Avatar
    Jan 2013
    Shenandoah Valley
    Hello Anke, I have 302470 with the larger bezel. I also have the non-adjustable struts and water bag in the fender.
    Alex in Virginia
    Looking for:
    ward to driving my car!
    Early 911S Registry # 2863
    Jan 2015
    Bonn, Germany
    Hallo Jim, Dave and VA Alfa,
    thank you for your help. Unfortunately I´m in holidays in Turkey and I can´t send a foto of the switch, but probably it is the large breeze I need. Because we only have the small brass bezel at the moment, we will use this one and change it later when we find the right one. Are there any good repros?
    Thank you. Kind regards.
    Anke and Bernd
    356 A 58 silver
    302485 light ivory
    2.4 T Targa black
    Macan GTS black
    Boxter S black
    BMW R 17
