Thread: Need help on removing gear from speedometer
    This is a 76 speedometer where the odometer stopped working. On the surface the gears looks fine, but I am thinking the stripped out part is hidden. To remove the gear looks, at least to me, that the brass part holding the plastic gear in place would need to be taken out first.
    Thanks for the help.
    1976 Carrera 2.7 MFI
    Ferrari 308
    '66 Hertz Shelby 350H
    '68 Shelby 500KR
    '68 Dodge Charger
    TR 6
    450 SL
    MC40
    G35
    Apr 2012
    SE PA
    The pot metal gear is slipping on the shaft on the end of the odometer drum. I am going through this right now on my 73. I ordered a gear and paid through PayPal and cant get them to respond to any emails. Your pic doesn't show that end
    How's this, the round brass fitting?
    So my question is how do I get the gear off?
    Ferrari 308
    '68 Shelby 500KR
    '68 Dodge Charger
    TR 6
    450 SL
    MC40
    G35
    Apr 2012
    SE PA
    Trying to add pic. Its the gear on the other end and its as big as the drum.
    Quote Originally Posted by gearjam View Post
    Could you see missing teeth before you took it apart?
    Ferrari 308
    '68 Shelby 500KR
    '68 Dodge Charger
    TR 6
    450 SL
    MC40
    G35
    Apr 2012
    SE PA
    Speedo
    Once you get the shaft and small sprockets out you push the shaft out of the drum. I used welding rod cut the inside length of the drum so the drum doesn't fall apart when removing it. The brass gear stays on the shaft so move it in that direction.
    Apr 2012
    SE PA
    No missing teeth. The gray gear in my pic is the one that is slipping.
    Senior Member 30westrob's Avatar
    Mar 2016
    SE Pennsylvania
    No need to replace the grey metal gear. With the gear off on a flat metal surface, use a flat punch and strike the center of the gear. This will reduce the diameter of the center hole, slightly. Test with the shaft for a snug fit, then reassemble.
    Rob
