Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: Question on 68 driveshafts one year only
  1. #11
    Jim, the thoughts and information that you offer are always welcome, as are Gordon's too.
    Jon B.
    Vista, CA
  2. #12
    1969MY CV Joints are 108mm diameter have 4 x M10 bolts on a PCD of 94mm and are 40mm wide.
    The SWB Joints are 98mm diameter have 6 x M8 bolts on a PCD of 78mm and are 32 mm wide.
    Drive shafts are also a different length
  3. #13
    Sep 2009
    UK
    Jim,
    i amended my reply from Jon to "guy's" as us Brits are very polite I must say, all the reply's are from guy's that always offer help and advice on this board. One of the reasons i'm here.
    Dave
  4. #14
    Jon B
    Many thanks for tot help.
    The interior of the flanges on this particular car don’t look like the one on the picture you posted.
    I will assume I won’t have to worry about them.
  5. #15
  6. #16
    Aug 2009
    SF Bay Area
    Quote Originally Posted by chris_seven View Post
    That is, of course, true.
    My point was that 68 and 69 (aluminum case trans) drive flanges will interchange. They are the only ones that will interchange between 68 and any other "LWB" transmission.
    Jim
  7. #17
    Jimmy, that looks like a great product.
    Just to be clear on the application years, those caps were first used on 912s in 65, and first used on 911s in early 66. They were phased out in early 68 when the simplified differential was introduced.
    Jon B.
    Vista, CA
  8. #18
    Is the cap and O ring jimmy t is selling the same as the one listed in jon's parts list: 901 332 239 10. Very familiar with this open diff application, retained with large wire snap ring. I've also done lots of 904 LSD's in 901 boxes with Nadella drive flanges and the same with Lobro conversion drive flanges, all of those took a hammer in cap with no O ring. Clarification please on jimmy t parts. Gordon
  9. #19
    Sep 2009
    UK
    Here are the parts i received. What are suitable for my future 68 build. ? Would appreciate what the other parts might fit so i can sell them on.
    Many thanks
    Dave
  10. #20
    The 2 long stub axles on the left and the 2 wheel flanges are SWB with CV's. The short stub axles are LWB. Can't speak for backing plates.
