Results 1 to 10 of 13
Thread: WTB: differential spider gear for 901 box 901 332 902 00
    I am looking for a large differential spider gear 901 332 902 00. The one with the splines. Mine lost a tooth. Many thanks,
    JK
    What year model is the application, easier to find. G
    HI,
    I need one for my '66.
    Many thanks,
    JK
    Not sure if it helps , but have a complete Differential from a 70 Gearbox available
    Let me know
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    JK needs a small 901 diff parts with the drive flanges posts. Those drive flanges have caps with O rings and wire snap ring. Sand cast ALU trans. Mag trans diff parts don't fit. As a note: 901/911/914 ring and pinion, gears and shafts can be interchanged.
    Hi,
    What I need is the big spider gear. There are two in the differential and two smaller ones. As you can see a tooth chipped off. No idea how it happened. Luckily it did not do major damage.
    JK
    Still looking, anybody?
    Aug 2009
    SF Bay Area
    Quote Originally Posted by 718RSK View Post
    J. I can probably scare one of those up for you. One would expect this to be covered under the warrantee
    Jim
    PS: Kinda busy right now but can do it after Rennsport
    36 year PCA member
    Dec 2012
    Denver Co.
    I have one loose from a 914, $50?
    Joris, if you can't come up with the single loose gear you need, I can offer you a complete 901 set and send it to Larry or another US address.
    Of course, there's always the Super Glue option too.
    Jon B.
    Vista, CA
