Thread: Window frame part
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Window frame part
Size:  54.6 KBHow is this part called and which Part number?
    Window frame bracket?
    May 2006
    CT
    Dirk
    Those screws and the bracket are part of the window frame assembly. Was that your question?
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Apr 2016
    Stuttgart, Germany
    Tom,
    I tried to remove the window frame to change the door lock.
    The bracket and screws aren’t listed in my spare Part books.
    Wonder that they used XZN screws to mount the bracket to the frame.
    Do I habe to remove the bracket to change the window frame?
    In a word,,,,no. If you are asking do those screws need to be removed to remove the window frame from the door.
    Apr 2016
    Stuttgart, Germany
    Thanks a lot
