Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 3 bar engine lid fasteners
    Dec 2010
    Southold, NY
    Just had my grille off and it was fastened with Allen head bolts and regular nuts; no Nyloc nuts or lock washers present. Those fasteners are what were present when I got the car 41 years ago. Being curious as to what might be correct, I consulted PET and found it called for six "pan head screw M 5 x 12" and six "rubber washer," with nary a mention of bolts or nuts.
    As in the photos:
    Originally: yellow zinc plated tall nylon lock nuts over DIN 9021 Aluminum over sized washers...don't forget the rubber washers (about the same dimensions as the aluminum washers, 2-3 mm thick, between the grill and lid.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Thanks Mark
    Are the allen head bolts the same as seat rail bolts or different?
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
