Results 1 to 10 of 10
Thread: WTB: trans output flange fixing bolt
    Mar 2004
    Castro Valley, Ca.
    as pictured. 80mm shank.
    1940 Mercury town sedan
    I have those, but just to make sure, what is your application model, year and using original drive flanges. Maybe pix. Gordon
    Mar 2004
    Castro Valley, Ca.
    trans is '69 going into a SWB car. flanges are 901.332.209.12 '68 type. I was told to upgrade from the original "nipple" bolt to the type pictured above.
    Restoration newbie.
    Jun 2007
    San Francisco
    Did you put the little block into your diff to stop it flying apart? 911-332-208-00.
    The nipples do serve a purpose as evidenced when they fail.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Mar 2004
    Castro Valley, Ca.
    Brad Mayeur built the trans for me several years ago. I assumed that installing it in a '66 car would not be an issue. (ha, ha)
    I sent a pic to Matt Monson & he said that the diff had been upgraded. he sold me the flanges & said to get rid of the nipple bolts. he sent one bolt, but that's all he had.
    The bolts I have are either 75mm or 77mm. These bolts are always used with washers as pictured. Gordon
    Mar 2004
    Castro Valley, Ca.
    after more careful measurement the one bolt I have is closer to 78mm. your 77mm seems the best match.
    how should we proceed ?
    I'll pm u.
    Restoration newbie.
    Jun 2007
    San Francisco
    I didn't measure the nipple bolts I have but can you simply cut the nipple off and be good to go? Take note these are a stretch bolt also, does anybody have a NOS one to confirm the original unstretched length?
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Restoration newbie.
    Jun 2007
    San Francisco
    I just measured one of these with the nipple. 76mm under the head to the end of the thread. Just cut off the nipple and you're good to go.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
