Results 1 to 10 of 10
Thread: 2.5 ST engine project W/ Complete MFI System
    2.5 ST Engie Project built on 1970 S Case # 6301910
    This is a nearly complete ST engine project that was discontinued by a client who perhaps decided he was too old to go this fast or spend this much money?
    I will try to list the details, but there are many new parts and reconditioned parts and assemblies. There is a link to a Flickr photo album that will provide much more detail. https://www.flickr.com/photos/terryw...57700892237984
    The major components that need to be yet purchased are: connecting rods and a twin plug distributor.
    You can purchase this engine and take it to your engine builder, or I could finish it for you.
    Case details:
    Cleaned, tumble finished case
    cylinder head inserts
    surface cylinder spigots
    Replace soft plugs
    clean piston squirters
    Boat tail bearing webs
    Spot face outside bolt holes
    Surface case half
    Line bore main to standard
    line bore intermediate shaft bore
    Reinforce #3 head stud inserts
    Shuffle pin engine case
    Thread insert 8mm studs
    Clearance for 3.2 oil pump
    Oil bypass update
    Crank shaft.
    66 MM crank (rods and mains .25mm under)
    Clean crank internal
    check run out
    magnaflux
    replace soft plugs
    groove center main bearing
    Polish mains and Rod surfaces
    Knife edge crank
    Ellipse oil holes
    Cross drill crank
    Balance crank
    Full set of new crank bearings and nose bearing
    New Mahle 90 mm RS Pistons and Cylinders
    Pistons
    Cylinders
    Wrist pins
    Circlips
    Cylinder Bases Moon cut.
    Cylinder Heads
    All 1969 heads 911-104-306-0R
    cleaned, tumble finished
    new intake guides
    new exhaust guides
    Flycut cylinder sealing surface
    Re-cut/refinish valve seats
    resize intake ports to 38MM
    resize exhaust ports to 36.5 MM
    twin plug
    new intake valves
    new exhaust valves
    Titanium vale spring retainers
    New valve springs
    Rocker arms and shafts Reconditiond
    Jerry Woods 80 series cams New in Box
    MFI Pump and System
    Built to 2.5 TR Spec matched to engine
    Red knob conversion
    ST Sports purpose Conversion
    Re-plated hardware
    Done by Gus at Pacific Fuel Injection
    Throttle body and stacks
    Stacks
    Modified to 46MM tapers to 40MM
    Replace bearings and cleaned
    mounting surfaces re machined
    Black chemical treatment of magnesium
    Throttle bodies:
    Re-bushed throttle shafts
    Enlarged throttle plates to 40MM
    Opening at stack side 40MM matched to stacks
    Opening at head matched to heads at 38MM
    Mounting surfaces re-machined
    black chemical treatment of magnesium
    MFI lines
    cleaned
    re-plated
    ultrasonically cleaned
    New MFI Pump support kit
    NEW set of MFI injectors
    Engine oil cooler
    Raceware head studs
    New 3.2 carrera oil pump
    New chain rails
    New cam gears
    New chain tensioner gears
    New MFI belt
    New timing chains
    New Flywheel bolts
    New Rod bearings
    New intake manifold insulator plates
    New oil sump plate
    New Gasket set
    Theres much more, contact for more details if your serious.
    $45,000 OBO
    I may separate the Long block from the Injection.
    [/ATTACH]HPIM3182.jpgHPIM3263.jpgHPIM3186.jpgHPIM3251.jpgHPIM3182.jpg
    Case work was performed by Ollie's
    $42,000 OBO
    Bump for a great engine project.
    For reference, what's the full case number? I think it's missing a digit. GLWS
    Peter Kane
    '72 911S Targa
    Banned
    Nov 2004
    Scottsdale, AZ
    Looking at the pics Peter it appears as 6301940.
    Best of luck Terry. Very, very smart not to assemble until a buyer comes along.
    Best of luck Terry.
    Thanks! Need to study a bit more next time!!
    Peter Kane
    '72 911S Targa
    Engine case number
    The answer is: 6301910
    One should not post adds without reading glasses?
    Bump,
    Ready to deal, or I can build and test run so it's ready to go into your project.
    1970 S Case w/ all the good work done.
    Price reduction, $37,000
    Price drop.....
    Price Drop $34,000.......
