Results 1 to 10 of 11
Thread: More progress
    Aug 2011
    Virginia Beach Va
    More progress
    I figured I would share some of the work Dave MILLER is doing the lower half of my front slam panel was totally shot but the top with the vin plate was in geat shape so before the blasting they removed the lower
    Half well this is what they did with sheet metal and skillsName:  IMG_3565.jpg
    Doug Lehman
    Member #2825
    1966 912
    1978 911SC Targa fun in the sun
    Aug 2011
    Virginia Beach Va
Size:  87.6 KBHere is some more pictures of a few more repairs that have been done
    Doug Lehman
    Member #2825
    1966 912
    Aug 2011
    Virginia Beach Va
    Getting things done
    The floors are out !!! Front end work 90% done !!! AS you can see a bit of tunnel work,a few flanges added. The heater pipes have some surface rust but are solid. WE are applying SEM Product to stop ant further corrosion.
    Doug Lehman
    Member #2825
    1966 912
    Senior Member 9er's Avatar
    Apr 2010
    Adelaide Australia
    Nice work, good pictures.
    Aug 2011
    Virginia Beach Va
    Here is an update on more work done on prep for the complete pan to be installed
    Feed back is welcome
    Doug Lehman
    Member #2825
    1966 912
    Aug 2011
    Virginia Beach Va
Size:  78.5 KBThe floor is finally installed.
    A look into the “smuggler’s box.” The opening for the steering coupler was mildly altered to match the original floor Name:  DSCN5032(1).jpg
Size:  87.1 KB Porsche ran beads of weld on some areas of the pinch weld flanges.
    You can also see one of the two brackets welded to the floor and pinch weld. Are they for A/C lines
Size:  82.1 KBName:  DSCN5042(1).jpg
Size:  76.8 KB fused pinch weld flanges increase the strength and stiffness in those areas Name:  DSCN5027.jpg
Size:  83.1 KBName:  DSCN5030(1).jpg
Size:  93.1 KBName:  DSCN5031(1).jpg
Size:  89.0 KBName:  DSCN5034.jpg
    Doug Lehman
    Member #2825
    1966 912
    Aug 2011
    Virginia Beach Va
Size:  48.6 KBName:  P204A.jpg
Size:  25.9 KBSO I know there have been discussions on the front tank supports on SWB cars
    Which one is correct for a 3/15/1966 Karmann build car. NY friends 1967 had this type of pan 204-e
    Does any know if this was a late 1967 -1968 thing or was it sooner
    Doug Lehman
    Member #2825
    1966 912
    Aug 2017
    el sobrante ca.
    Doug... The P204E is what my December 3 1967 Porsche built car looks like..... However the tray perimeter piece that is shown is not quite correct. the hold down piece of it is a little too wide and the corners should have more of a gap … see Dansk piece and you will see the gap in the corners of battery surround/flange goodie..... in other words you can easily modify the part shown...Name:  DSCN0113.jpg
    Note.... the hold down yet to be narrowed... only a few mm narrower...Name:  DSCN0112.jpg
    Feb 2013
    Europe
    Hi Doug,
    Just to give you some further information on the use of the P204E like support.
    The 8 September 1966 delivered 67s, we are working on, had it like that (large pressing) with some remainders of the battery tray.
    Since we found the pressings in the RD support not "sharp" enough, we decided to make the pressings ourselves.
    We bought a P204A like part but NO tray, since the tray was wrong, because of the reasons stated by Bob above.
    We made the tray ourselves.
    What was left of the original support:
    Name:  8. Links voor - battery tray terug voorzien.jpg
    How it was restored:
    Aug 2011
    Virginia Beach Va
    I think my biggest concern is did à 3/15/1966 build date have this tray or the short indentation.??
    Does anybody have this long one like the 204e before A 1967 Model year ?
    Doug Lehman
    Member #2825
    1966 912
