Thread: Interesting thread on Vredestein Tires and cold weather.
    Thanks moderator
    Apr 2008
    Virginia's Blue Ridge
    The issue is not just limited to Vredestein. It applies to any tire with rubber compounds designed for warm weather, generally called "Summer High-Performance" "Summer Performance" or "Summer Grand Touring Tires". If you run any of those and live where it often gets below 40*F and still want to drive, you should be prepared to switch to All-Season or Winter tires when the season arrives.
