Results 1 to 10 of 16
Thread: Wood Steering Wheel
    Aug 2017
    Toronto Canada
    Hi. What Year is the wheel?
    Jan 2017
    La Verne, California
    Did not see a date/year stamp on the wheel. I’m no expert but I believe it’s correct for 66-68.
    Jan 2017
    Just measured the wood wheel. It’s approximately 16 3/4. Just shy of the 3/4 mark.
    Hi Tony,
    Measure it in centimeters. Porsche, like the rest of the world, measured and built things using the metric system...
    Beautiful well. The wood looks like it has been stained darker than the original though. Maybe it's just the light.
    Horn ring is beautiful too... GLWTS
    Should be 420 mm
    Peter Kane
    '72 911S Targa
    Jul 2003
    Santa Cruz, CA
    Should be 420 mm
    Conversion of his measurement is 425mm ish. So, maybe a push toward the 68? Also I bet that excellent leather push is the type that was the leather bonded to the foam backing rather than the separate foam spacer. The separate foam pieces tend to disintegrate into dust.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Yep. Based on this comment, rounded down...
    "Just measured the wood wheel. It’s approximately 16 3/4. Just shy of the 3/4 mark."
    Peter Kane
    '72 911S Targa
    Jan 2017
    The first measurement was done using a seamstress tape measure. I just measured again using a wood yard stick. It measured just over 16 1/2. Just a bit over the 1/2 inch mark.
    Sorry for all the confusion. Did not know they came in different sizes. I will try to find the right tool to measure the width of the wood it’s self. Don’t want to add to the confusion.
    It’s a genuine wood wheel.
    Aug 2009
    SF Bay Area
    Should be 420 mm
    It is 420mm
