Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Help on wide S bumper trim
  1. #21
    May 2006
    CT
    Quote Originally Posted by Arne View Post
    So you are saying Stoddard is fine for the rear, but shill out for Porsche Classic for the front?
    Arne
    Yes.
    For the rears, I had both the Tasker repro and used Porsche original pieces in my stash. The Taskers were way off in profile. I bought the Stoddard repros and found they fit as well as the the original Porsche pieces.
    For the front, I had heard the Stoddard repro did not fit the bumper profile so I did not try it. I had also heard that repro rubber insert would not fit the Porsche classic Al trim piece so I went with the Porsche rubber insert.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
  2. #22
    May 2006
    CT
    Quote Originally Posted by Soterik View Post
    Tom, nice pics, looks pretty good. I get questioned on these parts as to best suppliers all the time (that and repro turn signal lenses). Can you show a picture of the rubber "joint" on the front rubber pieces?
    tks,
    Eric
    Eric
    The "joint" is barley visible.
    Tom Butler
    1973 RSR Clone
    1970 911E
  3. #23
    Aug 2011
    Eugene, OR
    Quote Originally Posted by 911GP View Post
    I'm no expert but I think the Porsche ones don't have a join at the tapered end whereas the repros do have a join.
    No, the 69-73 rubber does have a joint from day one OEM... but it's pretty difficult to see on original Porsche. The 1967S and 68S, and 68L had the one piece front and rear rubber with no joint (I make these).
    Eric, I wonder if @911GP was referring to the end of the aluminum base plate. I don't know if mine is original or not, but I note that is does have a seam where the aluminum was bull-nosed.
    - Arne
  4. #24
    Senior Member swisscheese's Avatar
    Jan 2003
    The Netherlands
    for what it's worth: I checked the original Porsche rear wide S-trim with the Tasker, but the curving of the Tasker was waaaay-off (too much curve). But need to compare to the current Porsche as well (the one I have is 20 years old/NOS).
    911S 1973
    Early 911S Registry #176
