Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: Price check on a Porsche factory tool
  1. #11
    Nov 2014
    New York
    -$25 per chip that flaked off.
  2. #12
    Hi, here is my one. This is the early style with wooden base, working and still going well.
    https://photos.app.goo.gl/tebn2jgSMhuzV9gL8
    https://photos.app.goo.gl/v4FwNYAZKdr9ZNiq7
  3. #13
    Jun 2011
    Mound, Louisiana
    Quote Originally Posted by 911kiwi View Post
    Wow, this is so cool, that you guys actually have these tools!!!!
    I agree!!! Very cool! Thanks for sharing!
    Paul Harrop 12.5% German.
    Early S #2059
  4. #14
    Quote Originally Posted by Alan.uk View Post
    Alan has a great example of the early version in his links, with the wood base and brass number plaque.
    Here is my gray paint version on the shelf. These were the three original paint colors that I've seen- blue, green or gray.
    I'm not in the mood to pull it down and clean it, and you can see how the paint is flaking off :-(
    Jon B.
    Vista, CA
  5. #15
    Restoration newbie.
    Jun 2007
    San Francisco
    I have a couple of those neat little height gauges is someone is looking to complete their head reco set.
    I think I have a P10B & a P10C.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
  6. #16
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Just a curious question. Is there a proper way to use this tool. Such as intake side vrs exhaust? Crazy I know. I have one of these too and it seems I have an asymmetric spring set up on mine! They do seem original but a little different height & spring coil count is 8&9. Note the different reach/angle on the bottom of the hoop, left & right......cliff
  7. #17
    Quote Originally Posted by Cliff View Post
    Is there a proper way to use this tool. Such as intake side vrs exhaust? ...I have one of these too and it seems I have an asymmetric spring set up on mine!
    Cliff, the tool is asymmetrical, and cylinder heads will only sit properly in one direction. In your photo, the intake side is on the right.
    If you measure various things on the tool, you'll see the pieces are different left to right, and the piston dome is offset too.
    Jon B.
    Vista, CA
  8. #18
    Correct me if I'm wrong, but were these for 2.0 heads. Did they make them for other heads. Did the change in valve angle and open combustion chamber affect the use of these tools. I had access to these but never used them. Gordon
  9. #19
    Correct me if I'm wrong, but were these for 2.0 heads...
    Gordon, I don't recall having any issues using the P200 on later heads through 2.7, but Porsche introduced the P200a in the 70s, a much simpler tool...
    Jon B.
    Vista, CA
  10. #20
    May 2012
    UK
    My old P200 is similar to Alan's -- a wooden base and metal finished with silvery blue paint -- also featuring the split/ join at top.
    Last time did job used the simpler P200a
