Results 1 to 9 of 9
Thread: Spring ring and spring washer - need clarification please
    Do I have it correct that a 'spring ring' is a split ring lock washer and a 'spring washer' is a thin wave washer...reassembling a few things and wanted to confirm the factory parts book terminology for these bits of hardware. Thank you.
    May 2006
    CT
    Great question....Subscribed
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Beware of English translation. Over time I was able to identify original locations of split, spring, star, snoor lock washers and made note of the German description. Then I only refer to German description. Plating is also sometimes noted at the end of the description.
    Oct 2010
    Southern Ca.
    Yes , from my experience generally correct . Spring ring is a split ring lock washer . And follow Gordon's advice .
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Let me know he part numbers and I will have a quick look on the German description
    Porsche used both Form A and B of each in different locations.
Size:  4.7 KB Name:  DIN137A.jpg
    DIN 127A = Spring ring, square ends
    B = Tang ends
    DIN 137A = Spring washer, curved
    B = Wavy
    Thank you Jimmy T...that directly answers my question. Some assembly tasks are obvious which of the two pieces of hardware go where, but I'm doing a few things now where it was not so this helps greatly.
    And further ..... Porsche part numbers go like this :
    DIN 127 form A or B = 900-027-xxx-xx
    DIN 137 form A or B = 900-028-xxx-xx
    May 2006
    CT
    And I suppose a “shackle locking washer” is just a round flat washer?
    Tom Butler
    1973 RSR Clone
    1970 911E
