Thread: Piston/Cyl ID Help
    Piston/Cyl ID Help
    Can someone tell me what type pistons and cylinders these are, taken from a 1965 911, previously rebuilt by PO. The photo of cylinder with 6 in triangle followed by 30- 0 is not the cylinder from which the piston shown was taken (this cylinder has the most clear marking). Thanks in advance for any help!
    John Schiavone
    Connecticut
    Looks like a normal 2.0 piston. Cast iron cylinder with height group 6.
    Thanks Gled49 -- so the PCs are original to the engine? Mahle? And the 4+ marking on the piston signifies what? (Other pistons have other designations.) Thanks again for the help!
    John Schiavone
    Connecticut
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Quote Originally Posted by John912 View Post
    Mahle?
    No it's KS = Kolbenschmidt
    ...so the PCs are original to the engine? Mahle? And the 4+ marking on the piston signifies what?
    Those are 2.0T pistons & cylinders, so are not original to your 65 engine.
    The "4+" is a Kolbenschmidt casting reference.
    Jon B.
    Vista, CA
    May 2006
    CT
    2.0T and 914-6 Kobelschmidt
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
