Results 1 to 2 of 2
Thread: Help with rivets for HELLA TTG housings
    I am trying to locate a machinist that can press the rivets of these rebuilt TTG fog lights. Have all the parts needed to complete. Photos #3 and #4 show an example of a housing with pressed rivets. The other photos are of the disassembled housing with rivets to be pressed. Any suggestions as to who could do the pressing would be most appreciated. Thanks in advance.
    Dec 2004
    SE Michigan
    Where did you get the rivets, by the way?
    Bill G.
    EarlyS #718 | RGruppe #437
