Results 1 to 10 of 14
Thread: Need help with steering
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Picked up my wifes Targa some days ago from the shop that does the engines of my cars. They worked only on the engine.
    My wife and I started a longer trip with this car this morning. While shunting into a narrow parking lot I realized that the steering doesnŽt react like it used to do before.
    If I turn the steering wheel toward end position, the wheels (including steering wheel) snap automatically towards the maximum angle/end Position and the tires sound like rubbing over the street.
    Before I will drive to a local shop (300km away from my regular shops): any suggestions where to look/what to repair?
    Banned
    Scottsdale, AZ
    Was it towed to the shop?
    Apr 2016
    Stuttgart, Germany
    No. I drove it to the shop.
    Forget to mention that the steering wheel was removed and they used an impact wrench
    to loosen the screw.
    Banned
    Scottsdale, AZ
    Nothing wrong with an impact. Why did they remove the wheel?
    Sounds like the caster abruptly changed. Or there's something going on where the steering shaft attaches to the coupler. You may want to open the smuggler's box and take a peek.
    Apr 2016
    Stuttgart, Germany
    The steering wheel was 1 or 2 teeth of middle while driving straight, so they had to remove the wheel to set it centered. They didŽd touch the tie rod setting.
    What is a caster?
    Banned
    Scottsdale, AZ
    So it begs the question; why was the steering wheel off center? It sounds like they didn't "correct" anything by re-positioning the wheel. The rack and tie rods should be centered before moving the wheel on the splines.
    Caster...
    Google is your friend.
    Apr 2016
    Stuttgart, Germany
    was:
    front toe +3° !
    rear: toe -0°20' !
    now:
    front: toe 0°, camber +0°10'
    rear: toe +0°20', camber -1°
    Apr 2016
    Stuttgart, Germany
    Frank,
    brought the car to the engine shop and ordered only to fix the engine and set the steering wheel correct. So not his fault.
    He raised the tire pressure of there tires to the correct 2,0 bar. The lower tire pressure lead to abrase the outer parts of the tire tread more than the middle parts.
    The cold weather and the higher pressure lead to less damping of the vibration. I was now also driving most likely on the inner thread of the front wheels.
    Toe-out was 0°.
    right rear was 1cm too low.
    Measuring is done by. Some of the EURO guys may know him and his patented aligner
    https://www.seibold-auto-sport.de/po...totechnik.html
