Thread: Replacing electrical components
    Dec 2013
    Connecticut/Florida
    I’m starting to restore my 911S. Most of the components are original and haven’t been replaced before. For example the components on the rear electrical panel. When folks restore are there components that should be replaced given the age, even if they appear to be working ok? Welcome the input.
    1971 911S Coupe - Gemini Blue
    Dec 2010
    Southold, NY
    You're on a slippery slope. Once you begin, where do you stop. If it ain't broke, leave it alone. The enemy of good is better.
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    Drive the snot out of the car as it is and replace original components only when they fail beyond repair...that’s my advice.
    Alan
    N.J.
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
    Nov 2003
    Santa Monica CA
    Just got a original 68 911L running and driving. I do not dare touch the electrical components on the car until I need to. Avoid that slippery slope. Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    May 2006
    CT
    On my ‘70E project, I had the CDI and MFI transducer rebuilt by Kurt at Partsklassic. The rest I left alone.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Banned
    Scottsdale, AZ
    The only rear relay board part that I would rebuild or replace would be the CD unit. I second the Partsklassic unit. Kurt does great work.
    The other relays and voltage regulator are not really "rebuildable" and you certainly don't want to buy current replacements! Clean them up and install new stickers.
    And definitely don’t replace the coil with current “replacement”.
