Results 1 to 8 of 8
Thread: Early 911s trunk carpet installation
    How was the trunk carpet on the two side pieces installed in early cars?
    Was it glued in along the sides or did it just lay in place?
    Were any of the fender bolts used to secure it?
    This is a 1967S
    Grand Prix Classics
    7456 La Jolla Boulevard
    La Jolla, California 92037
    United States
    Tel: (858) 459-3500
    www.grandprixclassics.com
    Facebook
    Instagram
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    Fender bolts have a tabs with snaps also at the top ( cowl ) for the center piece on the card board
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Gumby View Post
    You are referring to a LWB car. I'm assuming the OP is asking about a SWB car. I'm no mind reader, though.
    Note to all posters asking a question: Just state the year model of the car. "Early" or "late" doesn't get it.
    Jim
    You're right Jim, it's a SWB car, 1967. Any advice on the carpets?
    Grand Prix Classics
    United States
    Tel: (858) 459-3500
    Facebook
    Instagram
    Early cars don't use the tabs and snaps
    Grand Prix Classics
    United States
    Tel: (858) 459-3500
    Facebook
    Instagram
    67 were glued. Use sparingly and allow access to fuse box, etc. Your existing trunk should give hints unless it has been stripped.
    I've seen cases were the glue wan't so sparingly used -- loads of it dumped on the fuel filler tube and vent tube and lines. Question: Do you do the same for an authentic restoration where you've spent so much time detailing the trunk? I use small Velcro tabs to hold the side panels in place.
    John Schiavone
    Connecticut
    Feb 2013
    Europe
    If possible, it would be very helpful to add pictures of both the traces of glue in the trunk and the traces of glue on the carpet on an all original/survivor car.
    For me an authentic restoration is providing a car as it left the factory: with glue/NO velcro.
    If you just want a clean and functional restoration you can do what you want...
