Results 1 to 10 of 11
Thread: Is this car mfi.?
    Jul 2017
    Glendora california
    Is this car mfi.?
    Hello. Newbie question here. I found a 73 t thst is a few hours from my seller has only owned it for a short time and thinks it has carbs, I thought that the 73 Ts had MFI. Can you tell from this picture, I guess I don’t know what too look for and the only other cars I looked at had Weber’s
    Thanks in advance !!
    This is a U.S. T with MFI....
    Jul 2017
    Glendora california
    Chuck. Thank you!! I noticed some relay was missing on the drivers side so I was worried.
    Also 5he owner said it was carborated
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    No relays missing on the first view......but the AC compressor got lost somehow
    Banned
    Nov 2004
    Scottsdale, AZ
    Interesting to see what looks like a P233b fuel pressure gauge on it. Usually just for diag.
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    Quote Originally Posted by dirk07 View Post
    Translation:
    Potentially a factory A/C car as indicated by the ignition coil mounting bracket that creates space for the deck mounted components
    1969 S Coupe #761
    Early S Registry #1624
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Toddlaunchbaugh View Post
    I wouldn't be worried about the "missing" relay. I be really afraid of the owner/flipper, though.
    Jim
    Quote Originally Posted by beh911 View Post
    Translation:
    The other giveaway is the washer reservoir up by the smugglers box (but you had to check ebay for that picture)
    My suggestion: since you (and the Seller) don't seem to know the difference between Carbs and MFI, you should do more research and learn more about these cars before making a decision about buying an old Porsche. Knowing what you are looking at can save you a lot of money and disappointment. Once you know what you are looking at, and have found a good one, you will be in for a treat.
    EXCELLENT advice...…..
